2001 buick regal 3800 v6 bucking and clucking, )
Just found a project car to play with for a friend in need of basic transportation.
A 2001 buick regal with a V6 3800, the engine runs fairly normal on idle, on cold start, it is a little choppy, but once it warms up it runs better at low idle up to about 2500, above that and you get a real whopper of a mess.
Here is a video in case someone out there has seen this and found the cure.
buick - YouTube
Checked Air filter, (needs replacement) checked plugs (needs replacement)
checked MAF, appears to be newly installed.
Checked for collant leak, (not obviously leaking) no pressure test as yet.
I am going to replace the air filter and plugs and plug wires and test again but in the time being thought I would put this out there to see if someone had a thought or idea.
Really hoping to avoid the UIM LIM situation.
buick - YouTube
sound like you are hitting the rev limiter. the computer is pulling spark to reduce the chance of engine damage.
