2000 Honda Odyssey spins but won't start please help
Old 10-22-13, 01:58 PM
When I first start my van it starts just fine but if I drive it and turn it off it just spins and won't start. I wait a minute and try again it spins the finally starts. What could be wrong? It's my only means of transportation I need help please. Thanks
Old 10-22-13, 02:02 PM
the_tow_guy's Avatar
Received 39 Votes on 31 Posts
Likely an ignition problem. You've got an electrical/electronic component that is beginning to fail. When the vehicle sits for a minute after turning it off it reaches the highest temperatures under the hood. After cooling for a bit it restarts. Unfortunately these can be difficult to track down. Check back and maybe one of our Honda fanciers will be able to point you toward most common failure items.
Old 10-22-13, 02:10 PM
Thank You!! I will keep checking back.
Old 10-22-13, 02:13 PM
Old 10-22-13, 02:22 PM
Thank you for the link. I will give this a try.
Old 10-25-13, 09:52 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
Honda No Start? POSSIBLE Main Relay - EricTheCarGuy - YouTube
I think they finally rid of main relays, due to their proverbial anecdotal cause for ongoing issues. Fortunately, cheap and quite easy to replace.
