tail lights out
Old 11-02-13, 06:53 AM
tail lights out
2001 buick century dash and tail lights out
Old 11-02-13, 07:03 AM
Norm201's Avatar
Lets look at the obvious first. Is the bulb burned out? Is the fuse OK? If you can answer these two questions then we can go on to help you find the problem.
Old 11-02-13, 07:31 AM
I have checked the fuses and lights. they are ok.
Old 11-02-13, 09:54 AM
Norm201's Avatar
Could be a bad ground or a bad fusible link. I think I would start by using s VOM meter and see if any current is getting to the fuses. Then follow to the tail light harness and the dash board harness. This could get complicated.
Old 11-02-13, 10:46 AM
Welcome to the forums.
The dash lights are powered from the tail light fuse. Are you sure you checked the correct fuse ?
Trackbacks are On
Pingbacks are On
Refbacks are On
