traction control
Old 11-18-13, 01:22 PM
traction control
I have a 2003 chevy venture and do all the work myself Ive come across a problem never had to mess with traction control every so often the service traction control comes on along with abs light where to start. THANKS IN ADVANCE
Old 11-18-13, 01:55 PM
Received 5 Votes on 4 Posts
I'd start by looking at TSBs for your symptom.
There is a TSB for the connector pig-tail where it connects at the wheel, the wire gets broken from flexing and becomes intermittent. I believe that if you get the code read correctly it may tell you which wheel is the culprit.
Good luck.
Bob
