99 Olds spouting coolant
Old 11-25-13, 08:06 PM
Received 4 Votes on 4 Posts
My 99 Olds Delta 88 Regency with 3.8 litre 6 cylinder does not like to have coolant in the bottle "full cold" If I try to keep it full cold. It lets me know that it does not like to be at the full cold level, by leaving most of the coolant overflow tank on the ground when I stop the engine after coming home from work after getting up to normal temperature, probably from the hose that goes back to the radiator. I have tried new radiator caps, and just bought another one tonight. I have pressure tested the system, and I have no leaks anywhere when I pump it up. What else can be causing this? It runs at normal temperature (just under 200 degrees on the dash guage, and does not overheat, just dumps coolant when there is more in the overflow tank than it likes. It will not go below 2" from the "full cold" line when it does this. and it will expand in the tank to the "full hot" line with the remaining coolant when it has stabilized at the level it likes.
Old 11-25-13, 08:15 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
1. bad head gasket with bypass exhaust blow by into coolant
2. air bubble somewhere in the system. Bleed the system.
Old 11-25-13, 08:39 PM
iceman681's Avatar
Received 3 Votes on 3 Posts
crack in the coolant tank? leaks when hot
