2001 grand cherokee oil press drop
Old 12-01-13, 07:32 PM
The oil press drops to 10 psi to zero on idle, and rise when the RPM increase to 40 psi. The oil level seems ok. I don't see any oil leak. The engine temp is on normal range.
Old 12-02-13, 04:14 AM
the_tow_guy's Avatar
Received 37 Votes on 29 Posts
I would try replacing the sender unit. When it goes to zero are you getting any indication of actual loss of pressure? Knocking/tapping, etc?
Old 12-02-13, 06:50 AM
No, everything looks ok the motor and the others gauges are in range and I don't feel any other symptom. I can drive normal the acceleration and power are ok.
Old 12-02-13, 07:32 AM
Received 3 Votes on 3 Posts
When did this "zero pressure at idle" symptom start? Is this vehicle new to you or have you owned it for a while? What motor is it and how many miles on it? What is the service history?
Old 12-02-13, 07:48 AM
No any symptom, I drive this vehicle every day and I don't feel nothing abnormal.
Old 12-02-13, 03:35 PM
Best check would be to get a mechanical gauge on it to see what actual pressure is being put out. I was going to say just change out the sender, but I did a quick look-up and it's a pricey little bugger, about 30 bucks.
Old 12-04-13, 10:55 PM
wrench191's Avatar
Those oil senders fail a lot. If you don't hear the lifters at zero oil press. It is probably ok. Just to be on the safe side as you have been told check with manual gauge.
