windshield wipers out of sync
Old 12-15-13, 01:17 PM
2000 grand prix.. first they weren't working and now one moves and the other partially moves.. out of sync.. what could be the problem?
one seems stuck at bottom like it wants to move.. I did tighten the screws
Old 12-15-13, 01:42 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
These come in on each other right? Not sure when the changed that as I had a 1996.. What I found is the main spine holding the wiper gets stripped... Sometimes the wiper end itself... Have you removed it to inspect?
Old 12-15-13, 03:37 PM
not sure
can't tell if stripped.. two separate wipers that run in sync.. wtf could cause this?
Old 12-15-13, 04:53 PM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
You have one motor that drives a linkage. You should be able to tell if the arms or axles are stripped by pulling both off and comparing the good to the bad.
You may have to remove the cowl piece to check the linkage.
Old 12-16-13, 04:39 AM
the_tow_guy's Avatar
Received 259 Upvotes on 210 Posts
I'm thinking one of the wiper arms loose or stripped.
