Help for a 02 Chevy Venture
Old 12-17-13, 06:23 PM
I have an 02 chevy van I'm replacing the radiator. it's all ready to come out but it won't. tranny lines are disconnected. Hoses off. When I pull it up, the a/c cooling radiator comes with it. Any ideas?
George
Old 12-17-13, 07:53 PM
iceman681's Avatar
they are connected in some way. take a look at your new one and you will see how they hook together.
Old 12-17-13, 08:17 PM
ukrbyk's Avatar
Only a MVAC-trained, EPA-certified, automotive technician should service the A/C system or its components.
Recover the refrigerant from the A/C system. Refer to the Heating & Air Conditioning Section.
Drain the cooling system.
Remove the cooling fans with the cooling fan shroud.
| Repair Guides | Radiator | Removal & Installation | AutoZone.com
Old 12-17-13, 08:20 PM
ukrbyk's Avatar
Apparently you remove AC condenser and radiator as single unit, after AC was drained and disconnected, then separate condenser from radiator. Good luck.
Old 12-18-13, 05:06 AM
the_tow_guy's Avatar
Ran across that doing a radiator a while back on a Ford, too. Makes for a lot of extra labor.
Trackbacks are On
Pingbacks are On
Refbacks are On
