Jeep won't shift into park.
Old 01-06-14, 06:58 AM
Jeep won't shift into park when its cold out.
2000 jeep cherokee sport will not shift into park when its very cold out. For years I noticed it was a bit clunky shifting into park on realy cold days. This year below maybe 20degrees will not shift back into park.
any ideas?
Old 01-06-14, 09:19 AM
Received 120 Votes on 107 Posts
I think there is a cable that needs to be adjusted. I used to have a 1990 cherokee and the cable was replaced under a recall but they had adjusted it wrong and it wouldn't go into park fully enough to remove the ignition key - I'm assuming you have a similar type of issue.
Old 01-06-14, 02:33 PM
would that be temp related? The shift lever physically will not go past reverse when its cold out.
Old 01-06-14, 02:44 PM
Not necessarily but if the adjustment is marginal, cold temps could make it stubborn.
Old 01-10-14, 06:54 AM
found the problem. The shifter button has to much play before it engages. Any way to adjust or do I need to get a new shifter. In The cold I can shift inti park if I manually pull the cable further. currently it only slightly pulls when fully depressed.
Old 01-10-14, 09:22 AM
Look for the cable it's attached to, there might be an adjustment where it connects to the tranny. I'm sure it's got an adjustment somewhere. The dealer adjusted mine because they were the ones that messed up to start with.
