Service engine light on
Old 01-09-14, 04:55 PM
5
I have a 1994 Olds Ciera 57000 Mi. service engine soon light came on. My Auto Xray said it was a code P1405 EGR3 solenoid error. Could anyone give some information for checking it out. That is one thing I have never had go out on me. All replies will be appreciated. Thanks
Old 01-09-14, 06:05 PM
Received 4,049 Upvotes on 3,632 Posts
It says solenoid error because when it activates the #3 solenoid the ECU is looking for a large change that is not made.
The passage running from the EGR valve to the throttle body is, more than likely plugged solid with carbon.
You would need to at least remove the EGR valve to confirm the clogged condition. In severe cases the throttle body and the EGR valve need to be removed to clean the passage out.
Old 01-09-14, 07:06 PM
ukrbyk's Avatar
Received 63 Upvotes on 54 Posts
Remove EGR; spray liberally with carb cleaner; reinstall; be happy. Reset code.
Old 01-09-14, 07:38 PM
5
Thanks I will try that this weekend, and let you know the results
