2002 Chrysler Town & Country Rear washer motor
Old 01-18-14, 04:18 AM
N
Where is the rear washer motor located? I cannot find a location in my manual
Old 01-18-14, 05:32 AM
the_tow_guy's Avatar
Received 259 Upvotes on 210 Posts
I'm guessing there's a reservoir for the rear washer somewhere in the back, probably under a panel? The pump/motor will be attached to the reservoir most likely.
Old 01-18-14, 06:59 AM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
Can't say for certain...but I agree that if you have a separate reservoir it will prob be attached to that.
My SUV used only a front reservoir and had a combination front/rear pump. Just a hose running to the back spray head. The wiring was what determined where it sprayed from.
Old 01-18-14, 10:22 AM
Received 861 Upvotes on 753 Posts
I used to have a 1990 jeep [chrysler product] that used the front reservoir/pump for the back. You'd know if yours is the same by the extra tubing on the reservoir.
Old 01-18-14, 01:53 PM
N
Thank you for the input. That makes perfect sense
