Difficult Timing Belt Replacement Kia Rio 1.6L or Honda Fit 1.5L
Old 01-26-14, 03:53 PM
T
Which one is the most difficult to change Kia Rio or Honda Fit?
Old 01-26-14, 04:15 PM
ukrbyk's Avatar
Received 63 Upvotes on 54 Posts
Honda has VTEC engines. As the result, timing belt is also operating variable valve timing unit. At least, runs through it. It is very easy to mess that up.
If Rio has same, they will be adequate. 4 bangers otherwise are quite easy to do belt. V6-s are much harder, much easier to err by a tooth. Belt is mile long.
Old 01-26-14, 07:38 PM
the_tow_guy's Avatar
Received 259 Upvotes on 210 Posts
I think the Fit is a chain; that would make the argument moot.
Old 01-26-14, 08:00 PM
ukrbyk's Avatar
My bad, it's a chain. Lifetime likely then
honda fit timing belt or chain? - Honda-Tech
Rio has a belt and Mr friendly Youtube adviser
Kia Rio Timing Belt Replacement, 1.6L, I4, 16 Valve - Auto Repair Series - YouTube
Old 01-27-14, 04:35 AM
Side note on the Kia (as with belt-equipped Hondas). Gates replacement guide lists that as an interference (aka valve-bender) engine, so you want to be sure of your installation procedure.
