95 ford windstar van 3.8 v6 help.....
Old 01-30-14, 02:43 PM
C
Have 95 ford windstar van 3.8 v6, battery light stays on & won't start, has fire in the plugs, alternator & battery have checked out good, any ideas?
Old 01-30-14, 02:50 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Hello and welcome............
I fixed your title for a better response...
Anyway have you checked the fuel? Are you out of gas? Joking but you never know...
Sometimes a security feature shuts down the fuel.. Check pressures....
Old 01-30-14, 03:27 PM
C
Chuck Z
It's full of fuel. Chuck Z What are some of the security measures to check?
Old 01-30-14, 04:09 PM
lawrosa's Avatar
Super Moderator
First check fuel pressure at the rail to be sure fuel pump is working..
Security features turn the injectors off...
So check the pressures first then post back...
Best to get a haynes manual to help you along....
Old 01-31-14, 11:02 AM
is the engine turning over (cranking) and just not starting? or is it not turning over at all?
