Anti-Shphon Ball Removal
Old 02-24-14, 01:28 PM
A
I have a little cabin. In the past when running out of gas for my generator or chainsaw I'd siphon a bit out of my pickup. I recently started driving a 2012 Dodge Caravan. On my first attempt at siphoning gas I found the path was blocked. I learned that modern cars have anti-siphon balls in the filler tube.
Can anyone offer any advice on how I might remove this thing?
Preferably without dropping the tank...
I'd drill it out with a long flexi bit but I'm not sure what its made of and don't want to leave debris in the tank.
Old 02-24-14, 01:37 PM
Received 1 Upvote on 1 Post
Extremely bad idea on several levels.
Old 02-24-14, 06:19 PM
G
Received 2 Upvotes on 2 Posts
It would be a lot simpler to carry a can or two of fuel in the bed of the pickup.
Old 02-25-14, 08:12 PM
A
If anyone has an informed answer to the question it would be greatly appreciated...
Old 02-25-14, 09:24 PM
iceman681's Avatar
Received 5 Upvotes on 4 Posts
its made into the tank filler neck. removal of the tank is a have to if you plan to do this.
Old 02-26-14, 07:26 AM
B
Received 13 Upvotes on 9 Posts
I use a piece of snowmobile gas line, mine is blue about 3/8" OD. Sometimes you have to jack it around a bit to get by whatever is in there but it works. Not sure what a Dodge has though, might work.
Old 02-26-14, 09:11 AM
Received 24 Upvotes on 19 Posts
I think if I was determined to do this I would pick up a filler neck at the wrecking yard and remove the ball from it and get it ready to install.
I'd keep the original to re-install for when you sell the van or if the SHTF.
Old 02-26-14, 07:28 PM
A
Thanks
I did try a length of 1/4" tubing but I couldn't get it around the ball.
I didn't realize the ball unit would be integrated into the filler neck. I thought I might just be able to access and remove the ball. I'd not thought however of just replacing the filler neck. This is a really good idea. If I need to drop the tank it's not really a big deal, just something I was hoping to avoid out of laziness.
Thanks for the ideas guys. Very much appreciated.
Old 02-26-14, 07:36 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Do a search. There is some info on this subject...
https://www.youtube.com/watch?v=k39E2PRofIo
