GWM clutch problem
Old 03-10-14, 03:44 AM
H
GWM clutch problem
Hi All, I have had the clutch assembly replaced on a 2007 GWm, 2.2l long wheel base ldv. bakkie. I still have the original problem where the gears will not select, no visible leaks can be seen, and the clutch fluid resevoir is full
Old 03-10-14, 04:18 AM
the_tow_guy's Avatar
Received 260 Upvotes on 211 Posts
Is the slave cylinder on that internal or external (inside bell housing). Not sure you're going to find good advice here, your vehicle is limited to Asian, African, and European markets. Pretty sure most people here have never heard of it, much less seen one.
Old 03-10-14, 08:10 AM
H
Hi Thx! Got a technician who says it will be most probably the external clutch master cylinder - but would recommend we change the master & slave units
