No power on Kia Picanto
Old 03-10-14, 03:47 AM
H
Hi All
Please help!! I have a 2007 Kia Picanto hatchback and had valves and head gasket replaced, but the engine only idles, and will not rev up. The compression tests show up to be fine, although car is now smoking heavy
Old 03-10-14, 04:13 AM
the_tow_guy's Avatar
Received 259 Upvotes on 210 Posts
Does it respond to the throttle at all? Smoking heavily after engine work is not a good sign. What was the reason for the head job?
Gas or diesel engine?
Old 03-10-14, 04:21 AM
Received 856 Upvotes on 749 Posts
Are you sure the plugs are wired to the correct firing order?
Old 03-10-14, 08:14 AM
H
It is a 1.1l petrol engine. friend found water & oil mixing when he checked the oil level dipstick indicator. No, the car does not respond to the throttle at all
Old 03-10-14, 08:17 AM
H
Hi, yese we made double sure of this?
Old 03-10-14, 08:39 AM
Was the head work done at a machine shop? water in the oil is a big problem
Old 03-11-14, 06:07 PM
ukrbyk's Avatar
Received 63 Upvotes on 54 Posts
Heavy smoke.....
White? Black? Grey?
You have something wrong with fuel supply or timing. Or, throttle position sensor does not tell ECM throttle is opening and it does not act pump accordingly.
Or, you may simply have throttle valve diconnected.. As an oversight during reassembly.
Sounds like you guys winged DIY head job... Which is OK, done myself. But there is much that can go wrong thereafter, you know.
I'd say, you have coolant getting into combustion chambers, causing lack of spark and smoke...Sounds like a "do over" to me.
Old 03-12-14, 04:58 AM
And do you have access to a scanner?
