1999 chevy suburban overheating
Old 03-24-14, 12:47 PM
My 1999 chevy suburban 2500 keeps over heating. Temp gauge goes all the way up and then comes back to the 3/4 mark. So far I have replaced the radiator, top end hoses, heater coil, thermostat, and the engine coolant sensor. I am out of ideas can anyone help
Old 03-24-14, 12:53 PM
Rough Rooster's Avatar
Take it to a shop that has a tester for combustion gases in coolant. Have it tested before you spend any more money.
Real high probability you have a crack in head(s).
That requires engine surgery to correct.
Good luck!
RR
Old 03-24-14, 04:49 PM
Electric fan ? Mechanical fan with " fluid drive clutch " ? " Solid " mechanical fan ?
I had a truck that would almost instantly go HOT . Then settle down , when I slowed down .
Radiator shop said some left over debris ( possibly part of a " core " ) was inside one of the engine coolant passages and moving around . It would , from time to time get turned sideways & act as a shut off valve & block coolant flow .
For what ever it may be worth or not worth .
Also , possibly , the radiator hose on the suction side of the water pump , collapsing ? Bad water pump ? Air in the coolant system ?
God bless
Wyr
Old 03-24-14, 09:24 PM
ukrbyk's Avatar
Tim, RR aced it for you. Leaking head gasket. Exhaust getting into coolant.
