2011 town and country
Old 04-01-14, 05:32 AM
Can not remove key fob, van will not turn over, gear shift locked in park, lights, horn and door locks work, windows do not.. Used safety release on dash to release gear shift, no help. Turned wheels lock to lock and tried to remove key fob..no luck
Old 04-01-14, 07:40 AM
Gunguy45's Avatar
Super Moderator
You may have a bad cylinder. Can you turn the key? A locksmith can probably pull the cylinder and remove the key, then re-install a new cylinder. Though...it may have to be towed to the dealer or a mechanic. Looks like it may be a dealer only part.
I had a similar issue where I put the wrong key in a worn cylinder and couldn't get it out. The locksmith just grabbed it with a pair of pliers and yanked it out. Of course this was an old style key with no electronics in it...just a rubber coating.
