2007 Ford Taurus- Can't turn heat off
Old 04-24-14, 10:53 AM
Question 2007 Ford Taurus- Can't turn heat off
2007 Ford Taurus- Can't turn heat off. The heat or cold dial only gives me heat nothing happens when I turn it to the blue cold side. If I turn the air button on I can hear the compressor come on but that makes no difference. Is it the switch or is it something under the hood that the switch controls? Any help would be appreciated.
Thanks,
Wayne
Old 04-24-14, 11:42 AM
carguyinva's Avatar
odds are it's the blend door actuator under the dash that moves the door to blend hot and cold air together...
Old 04-24-14, 01:25 PM
ukrbyk's Avatar
Knowing Ford, you likely to run same dial I had back in my 87 Taurus. Same problem. What happened, there was a delryn connector behind the dial, if you take entire assy out. That connector had a long wire connected to it, to operate blender door. Well, that connector ear broke off.
Old 04-25-14, 07:12 AM
Thanks for the info. Is it something I can get and replace?
Old 04-25-14, 07:17 AM
Thanks for the reply. Is the actuator something I can get and replace?
Old 04-25-14, 08:21 AM
Old 04-25-14, 07:51 PM
ukrbyk's Avatar
Thank you, Liroku, very useful.
I glanced at that NEW Taurus dash, and like I suspected, knobs are exactly same they were back in late 80s.
In my case, knob shaft had a plastic "ear" that broke off. All I had to do was to pull climate control unit out and don't remember, I think I mended it with some wires.
Old 04-26-14, 07:52 AM
Thanks for the info it was just what I was looking for, a Great Help!
Wayne
Old 04-26-14, 08:47 PM
ukrbyk's Avatar
Any time, Wayne. ------------------
