2005 Malibu Classic Multiple issues
Old 06-20-14, 11:44 AM
V
I am a single mom trying to work on a tight budget so I am hoping I can fix some of these things myself. The first issue is that one of the brake lights does not work. The bulb is good. Could this possibly be a brake pedal switch issue or would that make both brake lights go out? If it could be the brake pedal switch, is there a way to find out for sure BEFORE buying a new switch? The second issue I have is that the buttons on my climate control panel have started working intermittently. Is there a way to fix this without buying a whole new panel? Thanks in advance for your advice.
Old 06-20-14, 11:49 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Nope...not the switch. More likely corrosion in the socket or connector...or a bad ground.
Dunno about the buttons.
