you think 4.5" 114.3 rims can fit on 4.53" 115mm lugs?
Old 07-14-14, 08:38 PM
P
All tires are bad on my car so instead of buying 4 tires and then paying to have them derimmed and put on, then alignment. I figured I could buy so.e rims and tires for cheaper then get an alignment.
So tires $100+ mounted $80-100 + Alignment $90.
Or rims and tires for $100 + alignment.
But will they fit each other? 114.3mm rims and 115mm lugs?
Old 07-15-14, 07:16 AM
WHEELS are a critical safety item! If it isn't an exact fit I would forget it. Check an interchange manual that wrecking yards used to use and see what is listed for WHEELS that fit.
Old 07-16-14, 04:29 PM
R
Exactly,,,, wheels are not the place for barnyard engineering. If they don't fit exactly you are risking losing a wheel.
