cherokee radiator fan blades.
Old 07-27-14, 11:36 AM
C
Its the second time, that it was broken wiht no apparent cause and damaged the radiator.
I dont have any idea why it occurs. The two last times was occured few seconds after start the engine.
Old 07-27-14, 01:10 PM
Received 851 Votes on 797 Posts
Did you have the first fan replaced by a mechanic ? Did he say why the blades broke.
It's pretty rare for the blades to just break. I remember flex fans had some issues but OEM type blades did not.
Old 07-28-14, 03:02 AM
Received 229 Votes on 204 Posts
Does it have a clutch fan?
Old 07-28-14, 04:09 AM
F
Also check the motor mounts. A bad mount, or mounts, can sometimes allow the engine to shift/move enough to allow the blades to hit the radiator and/or cowling (this usually happens with it in gear tho).
