Hyundai Sonata 2013 brake
Hi,
I've recently noticed that my 2013 hyundai sonata would start shaking, if I were to release my brakes slowly (It doesn't shake if I release it fast). I was wondering if there are any problems with that?
I do not feel any vibration in the car when I press /slam the brake. The only time I feel the car shaking is when I would slowly release the brake.
Thanks in advance
Thanks in advance
DIY type? Remove brake pads and caliper guide pins and LUBRICATE everything, including pads seats on caliper, with caliper grease. GENEROUSLY. Caliper should easily slide back-for about 1/4 inch on rotor.
When was brake fluid changed?
As it basically sounds like either pads are not releasing smooth enough, well, one side actually, or caliper starts having some back pressure from the system.
2013? Naahh, brake fluid is likely OK. I'd bet on sticky pads and guides.
