Vehicle Rocking Back and Forth
Old 09-20-14, 07:04 PM
Received 2 Votes on 2 Posts
Okay, so new bearings are $25 each. Not bad at all, and I'll re-use the original seats and mounts. SHOCK ABSORBER ASSY., R. FR./FRONT SHOCK ABSORBER (1) for 2008 Acura MDX
Old 09-20-14, 08:18 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
While you are at it, I'd replace the rubber cushions under the springs as well. Assuming you have them.
  #43
Old 09-20-14, 08:25 PM
Which rubber, item 2 or item 3?
  #44
Old 09-21-14, 06:40 AM
B
on each corner of car, push down hard and let go,did it come up & stay or go down & up another time?? if it didn't stay, the strut is weak and can cause the rocking
  #45
Old 09-21-14, 07:23 AM
Gunguy45's Avatar
Super Moderator
3 and 4 was what I meant. One is L one is R.
  #46
Old 09-21-14, 07:50 PM
Gotcha.
I tried the push test and it was inconclusive. I couldn't get a good grip on the fender so I neee to try again. I can't imagine what else it could be. It does feel better since doing the rears.
  #47
Old 09-22-14, 07:34 PM
ukrbyk's Avatar
Received 7 Votes on 6 Posts
If you can't grip fender, open door, stand on door step, and rock car, holding to roof rack or upper door jam portion.
