Alignment Sheet Nomenclature
Old 07-29-14, 07:24 PM
Just got an alignment and I'm confused by the nomenclature used in the printout. For example, instead of using decimal points to express fractional numbers (e.g. -0.34), it uses a degree symbol and a hyphen (-034'). I've seen this before but never quite understood why the specs are expressed this way.
Old 07-29-14, 07:45 PM
ukrbyk's Avatar
Because they are supposed to be measured in degrees. It's Zero degrees 34 seconds. Basically, at Zero. Say, how you gonna measure camber in decimals?
Old 07-29-14, 08:02 PM
34 seconds??? Is that just 34 one-hundredths of a degree? If so, thats 0.34 degrees.
Old 07-30-14, 02:28 PM
It's actually 0 degrees, 34 minutes and minutes/seconds can easily be converted to decimal notation and from decimal back to minutes/seconds. Here's a good explanation: Degrees, Minutes, Seconds | Zona Land Education
So, for my vehicle, the conversion is as follows (someone please confirm/deny):
Caster: 412' +/- 35' = 4.2 +/- 0.6
Camber:
Front: -030' +/- 1 = -0.5 +/- 1
Rear: -030' +/- 45' = -0.5 +/- 0.75
Toe for front and rear are given in inches, so no conversion necessary.
Old 07-30-14, 02:49 PM
pugsl's Avatar
been 10 years since I was alignment tech but if I remember right most specs are in degrees. Usually it can be changed in the machine to show inches but there is no reason to do so.
Old 07-30-14, 03:01 PM
I've never seen alignment specifications noted in anything but degrees.
Remember, you're dealing with angles and, as such, degrees are used.
Old 07-30-14, 04:35 PM
ukrbyk's Avatar
Yes, it's minutes and seconds, not just seconds. Good reminder. either way.... Nothing wrong with the chart.
Trackbacks are On
Pingbacks are On
Refbacks are On
