Window Wipers default to Upright postion
Old 08-17-14, 03:18 PM
F
Received 1 Vote on 1 Post
2001 pontiac montania. The Window wipers default to the upright postion when turned off. They work normally otherwise but for some reason now when you turn them off they go down but they go back up and stop. Is it a sensor issue? They work normally otherwise but default to upright when turned off.
Old 08-17-14, 05:31 PM
D
there is a mechanism that controls the park feature on these. Somehow they get messed up and need to be replaced. I had one of these and was able to fix it the second time it did it. It has been a while so I can not describe how to do it. You have to watch the mechanism a couple of times to see how it is supposed to work. I do recall having to drive out a pin to get it re-sequenced then put it back in
