2013 Town & Country Tire Pressure
Old 09-12-14, 06:09 AM
H
Second time the tire pressure monitor has gone off. Last time it went away after the car sat a bit and I restarted it. Not this time. Checked the tires and they're all good so I'm guessing it might be a problem with the monitor itself. How hard is this to replace?
Old 09-12-14, 06:35 AM
Received 1,475 Votes on 1,363 Posts
You could be looking at a costly repair. Is the vehicle still under warranty ?
Old 09-12-14, 08:20 AM
Received 398 Votes on 354 Posts
The ones on my jeep are extra sensitive, a 2lb drop in air pressure will turn on the idiot light. It might not take much to set yours off.
Old 09-12-14, 08:45 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Would it still be under warranty? I guess not, or you wouldn't be asking, but there may be a tech bulletin of some sort on it.
Old 09-12-14, 08:48 AM
E
As marksr says it doesn't take much on some vehicles with TPM systems to throw on the light. Even minor variation of 2 PSI between tires can cause it on some vehicles. Did you check the pressures with a digital tire gauge? If not I would do that as a next step to confirm that your issue is not something as simple as that.
Old 09-16-14, 02:46 AM
H
The light went away again.
The car has a CPE warranty with a $100 warranty. Since the part I've seen online is significantly less than that, if I can do it myself, it saves me some time.
Old 09-16-14, 05:13 AM
Have you checked the air pressure right after the light comes on? Tire pressure can change with both air and tire temperature changes.
Old 09-16-14, 10:47 AM
G
Received 2 Votes on 2 Posts
Are you past the factory three year 36,000 mile warranty? If not, take it to the dealer.
