bad fan switch
Old 09-13-14, 10:51 AM
bad fan switch
we have a 2000 pontiac grand am.....the fan switch is not working properly....at first the low speed (1st 3 speeds on the dial) would not work but the fan worked on high speed....then it quit working altogether....then the fan wold come on even with the car turned off and kill the battery.......i finally pulled the fuse....how do i go about fixing/replacing the switch....is there more involved than just replacing the switch.... Thanks
Old 09-13-14, 11:02 AM
There is a resistor block and possibly a hi speed bypass relay. I would start by changing the resistor block which is mounted to the duct work, just to the left of the motor, and behind the glovebox.
This video may be helpful to you.... you tube/watch?v=F034sa859Vw
Old 09-13-14, 11:41 AM
Handyone's Avatar
the resistor block which is mounted to the duct work, just to the left of the motor, and behind the glove box
Yes,
I've changed a few of these. When you do get the old one out, you'll see it looks a little "burnt".
