stop belt squeak?
stop belt squeak?
Our 2005 Kia Optima began having an intermittent issue with a belt squeak. Happens just now and then, for a while usually, then goes away. Doesn't seem to fit any particular pattern as to whether the car was just started operating or been operating a while. Sometimes might last for a few blocks of driving, sometimes just short 10 or 20-second periods of time. Always seems to stop though, so far, but rather annoying and concerning, even though it really doesn't do it very often (yet anyway). Pretty sure there's only the one big long serpentine belt, and it "looks" okay. I mentioned it to the mechanic at an auto repair shop, how it is intermittent like that, and how if I was to bring it in it likely would not make the noise then for them to easily diagnose. His suggestion was just to either wait until it starts doing it more often or regularly and then bring it in to be looked at, or that meanwhile I might try taking a wire brush while the belt is running (being careful of course) and sort holding the brush into the grooves of the serpentine belt while spraying a little silicone spray into where the brush and the grooves are touching. He said that might remedy the problem, and if it doesn't to go from there for continued troubleshooting otherwise. Comments? Before I try?
Received 0 Votes
Squeaky belt usually means the tension is low. Carry a bar of soap, and when it starts squeaking, CAREFULLY hold the soap against the tapered and inner edges (where it contacts the pulleys) while it's running. If that stops the noise, it probably indicates the belt needs to be tightened up just a little bit.
You can also use an anti-squeal spray, but you're probably going to pay $7-$10 for even a small can, and it's not something you want to keep putting on the belt, as it will build up residue and cause issues in the long term.
I'll try the bar of soap trick just mentioned I suppose. I'll bet when the belt starts squeaking, I'll jump out open the hood and by then the squeak will have stopped. thats how it acts,but we'll see, I'll keep that in mind, and try if I can. thanks
my luck this will turn out to be bearings in a pulley, something like that, expensive/extensive to fix
I had a Ford van with a serpentine belt that would squeal..... usually more in the damp and wet weather. I carried a lumber crayon. Just a light touch to the ribbed side was all it took and it was quiet for months.
That anti squeal spray is like a shellac and does make a mess.
Received 0 Votes
Belt squeak is a different sound from bearings... imagine the squeak of rubbing a balloon, only higher pitched. Bearings will be more of a metallic scraping sound.
If you can, try grabbing a video of it with your phone (assuming you have a phone capable of video recording). Doesn't even need to be high-def, just needs to capture the sound.
I had a Ford van with a serpentine belt that would squeal..... usually more in the damp and wet weather. I carried a lumber crayon. Just a light touch to the ribbed side was all it took and it was quiet for months. That anti squeal spray is like a shellac and does make a mess.
Belt squeak is a different sound from bearings... imagine the squeak of rubbing a balloon, only higher pitched. Bearings will be more of a metallic scraping sound. If you can, try grabbing a video of it with your phone (assuming you have a phone capable of video recording). Doesn't even need to be high-def, just needs to capture the sound.squeak.
Does it get any worse if you turn on things that will load the belt, like A/C?
Received 0 Votes
Understood... things like turning on lights or the rear defrost or blower fan will put a brief load on the alternator which will load the belt and could cause squeal if it's a hair loose. If it has A/C you could try switching that on just to test.
BTW, in a lot of newer cars, when you put the heater on defrost, it will also engage the A/C, as that dries the air and will clear the window faster.
things like turning on lights or the rear defrost or blower fan will put a brief load on the alternator which will load the belt and could cause squeal if it's a hair loose. If it has A/C you could try switching that on just to test. BTW, in a lot of newer cars, when you put the heater on defrost, it will also engage the A/C, as that dries the air and will clear the window faster.
Try turning on lights, blower and rear defrost all at once, that should put a pretty good load on the alternator.
Received 0 Votes
From this article: How to Change an Alternator on a KIA Optima - Kia Dealers Articles - MerchantCircle
"Mount the accessory drive belt and adjust its tension with the tensioner adjustment bolt. A new belt should have a deflection between 0.22 and 0.31 inches. A used belt should have a deflection between 0.33 and 0.45 inches."
In other words, if you push down on the longest free portion of the belt, it should deflect only about a quarter inch for a new belt, or just under a half inch for a used belt.
This is a "generic" drawing, but it will give you the basic idea.
