po135,po053,po030
Old 12-22-14, 01:02 PM
po135,po053,po030
These are all codes that came up when I had a friend put my 06 HHR Chevy on the reader po0135, po053, po030. I think if I can find the po135 oxygen sensor I can probably take care of all the problems right there because I think it's loose I never had any problems until I hit a bad pot hole, then it statred messing up on me since then that's been about a month ago the car runs the same it's just the engine light won't shut off even after I had the codes wiped out. If you could please describe in detail where I might find it and what it looks like I'd be eternally grateful. You see I'm no mechanic, but the company I was working for done a bunch of cut backs and that put me in the unemployment line. I have no way to pay anyone to do this so if I don't do it myself it's not only not going to get done but it's going to get worse until I have a real problem. Any help will be appreciated THANK YOU.
Old 12-22-14, 02:33 PM
The O2 sensors are usually VERY hard to remove.
Get a buddy to come look at it with you, someone who is mechanically inclined. It would likely save you time & money.
Old 12-23-14, 05:29 AM
the_tow_guy's Avatar
A loose O2 sensor would be pretty unusual; chances are just a bad sensor OR could be a wiring/connector issue.
Some help available at autozone.com:
http://www.autozone.com/repairinfo/r...96b43f80cb2e3e
You may need to login/register to access.
Old 01-03-15, 11:33 AM
appreciation
Thank you for all your help I appreciate it, thank you.
