2001 Honda Odyssey A/C seized
Old 12-29-14, 06:57 PM
My 01 honda Odyssey A/C compressor clutch seized and broke the belt. Can I replace the clutch without removing the compressor from the vehicle?
Old 12-29-14, 08:16 PM
iceman681's Avatar
the chances are if the bearing seized it was super hot at some point and the whole compressor has been weakened. or at least the front seal, and you will be fixing again in a month or two. save yourself a headache and just replace the whole compressor.
Old 12-30-14, 08:43 PM
ukrbyk's Avatar
It really depends on your vehicle configuration.
Should comp be real low down there, you likely be able to access it via removed wheel and fender cover.
But the thing is - clutch really does not seize by itself. Bearing falls apart and clutch can go crooked. But if it still sits plumb on the comp shaft - but won't turn - then your comp is seized. As if the ac pulley and clutch seized together - they should still be able to spin functional comp.
Old 12-31-14, 07:56 AM
the_tow_guy's Avatar
You may also find the clutch assembly could be pretty pricey.
