2000 Toyota Corolla battery/startup issue
In December the battery on my Corolla died and replaced it with a brand new one.
It worked fine for a few weeks then all of a sudden the engine would not crank, lights radio come on but when starting up - one click and everything dies and I lose radio and lights.
I notice the post terminals were corroded so I cleaned them - no change, replaced them, no change and the wires themselves had no visible corrosion or damage.
The car jumps fine when I hook up cables from my truck to the battery and runs great but the moment I turn it off, it will not start.
Defective battery maybe? Just had it tested it and Came back 12.64v and 503 amps. So more than enough to get the car started.
I'm out of ideas, if it cranks fine with starter/jump cables then it must be something between key and battery (not battery to engine) right?
Help!
Help!
I took the battery down to advance autoparts to have it tested, I'm guessing I should've taken the entire vehicle down there to get it tested while running and get the alternator tested.
It sounds like there either isn't enough juice stored in the battery, bad connection or the battery isn't getting charged properly. As Joe asked, was the battery load tested? have you tested the alternator? checked the connection at the starter?
edit; it sounds like they did a load test but you really should go back with the vehicle so they can test the charging circuit.
If you have access to a volt meter, get the engine started - jump or whatever - then check the voltage at the battery at fast idle. If you are not showing 14.5 - 15 volts, the alternator is probably shot. You can also look at the headlights with the engine off and then start it. If they do not brighten a bit you probably have an alternator problem.
Well, if car starts off jumper cables, I am presuming - connected to battery cables, just like everyone does - then everything from the very tip of that cable clamp outside to the starter, including ignition switch, is OK.
That battery sure has nuff juice to crank. If a parts store proclaimed it good, then it's good.
Strange it may sound, but the only thing I may think off is that something is wrong between the battery poles and cables terminals INSIDE. Though OP claims all that was cleaned.
It's enigma. I vote for simply trying different known good battery, thus eliminating battery as culprit.
Hey, OP - how exactly do you have jumper cables connected? To the cables terminals on battery poles, or to the exposed cables BEFORE the terminals? Thing is, those terminal;s should have additional connection between the cable terminal and the cable itself. 10mm bold holding it all together. THAT connection goes corroded just like anything else.
I'm connecting the jumper cables to the battery over the connectors just like anybody else would I even replaced them thinking it may been something wrong with them but no change.
Baffled.
Baffled.
