Rear windshield wiper not working
Old 02-08-15, 01:43 PM
B
Unhappy Rear windshield wiper not working
I have a 2004 gmc envoy xuv the rear wiper quit working, I don't have an owners manual to check it out to she what is going on with it any help will be appreciated, oh one more thing where can I find an owners manual for a 2004 gmc envoy xuv thanks for any help
Old 02-08-15, 01:57 PM
G
Received 2 Votes on 2 Posts
First check your fuses. Next test is to wire a test light up to the wiper motor. If the bulb does not light or the light intensity does not vary as you change the speed settings, the switch may be bad. If the light does vary, replace the wiper motor.
Old 02-11-15, 08:03 PM
A
Good advice from goldstar. Its either a switch, fuse or motor. Hopefully just a fuse.
Old 02-12-15, 06:03 AM
W
Received 34 Votes on 31 Posts
Manual
Is this the manual you wanted?
http://www.vadengmpp.com/owners-manu...-GMC-Envoy.pdf
Old 02-12-15, 06:09 AM
Received 405 Votes on 361 Posts
Rather than getting an owner's manual I'd suggest getting a repair manual for your vehicle as it will have more detailed info on making the repairs you'll likely have to make along the way.
Old 02-12-15, 06:20 AM
A
Received 72 Votes on 65 Posts
Don't know, but I would suspect that there might be a second switch at the tailgate, to prevent the wiper from operating when the gate is open. Just thinking that if there is that might be most susceptible to physical damage.
Old 02-12-15, 11:50 AM
Received 11 Votes on 8 Posts
Did the wiper get sluggish, slow down over time and one day not work at all.
Or did it just up & quit out of the blue?
Old 02-15-15, 11:23 AM
B
rear wiper not working
thanks for the info. I will try all the suggestions and will try the web site for the owners manual thanks again big hammer
Old 03-01-15, 03:07 PM
B
rear wiper not woking
it was a simple fix had a blown fuse thanks for all the help big hammer
