need some help 1995 ford Taurus stalls after starting
Old 02-27-15, 06:25 PM
was running great next morning i went to get in and go somewhere and it started but as soon as i gave it some gas it bogs out and stalls. we have checked the fuel filter and the pump seems to be running fine as gas is getting to the engine. it will start and idle for a few it's just when you give it gas it stalls out sometimes it does make a pop sound through the tail pipe. someone told me it might be the catalytic converter but i do not want to buy one and have it put in without really knowing if it's that. any suggestions on what it might be that a grandmother of 50 can do herself. i have tools and am able to get greasy.lol
Old 02-27-15, 06:41 PM
Welcome to the forums. (we'll have to call you greasy grannie)
It wouldn't be the catalytic convertor.
The fuel rail pressure should probably be checked. You'd need a screw on pressure gauge for that.
But it sounds mostly like an EGR(exhaust gas recirculation) valve problem.
Old 02-27-15, 07:19 PM
michaelshortt's Avatar
Check for codes, that may save you a lot of money
Old 02-27-15, 07:33 PM
Thank you both Michael and PJ. am going to check on the Valve. will let you all know how it turns out. Greasy Grannie
Old 02-28-15, 03:52 AM
A plugged cat convertor robs the engine of power but it would still run.
If you can limp it down to your local auto parts store most of them will read your codes for free.
Old 02-28-15, 06:08 AM
Is it a 3.0 or 3.8 engine?
Did this symptom happen "all of a sudden"?
How many miles on vehicle? Have plugs, wires etc been checked/serviced regularly?
Old 03-07-15, 05:23 PM
3.8 and yes all of a sudden drove fine night before then went to go to the Dr. and it would not stay started. have changed the plug/wires oil change and EGR valve and tubes. still won't stay running. idles for a few sec. then dies. i am stumped and autozone don't carry the code reader for this car. Greasy Granny is pulling her hair out. what little she has left. LOL
Old 03-07-15, 06:22 PM
My 94 thunderbird is the same way, most code readers won't work. Might find a good mechanic and pay to read the codes. Might save you money in the long run.
Trackbacks are On
Pingbacks are On
Refbacks are On
