check engine light
Old 03-04-15, 10:42 AM
A
check engine light
Good day to everyone. I have a problem with check engine light with my 2008 honda civic. I replace my headers with a weapon r and i also put weapon r cel eliminator. But my cel is still on. And if i erase the codes with obd2 scanner it does means the check engine light will turn off.
I hope you can help me to figure it out. Thanks..
Old 03-04-15, 11:15 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
You would probably be better off looking for a Honda specific forum that deals with modifications. Or contact the company directly, you can send email direct to their tech support.
That said, normally resetting the CEL will not be a problem as long as it's not flashing. If it comes on again, then you may have an issue.
Old 03-04-15, 11:18 AM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
You always need to clear the codes after performing any sort of repair. The light doesn't just go off on its own.
