2001 Toyota Camry Camry CE ck engine light
Old 03-11-15, 07:11 AM
I have replaced the engine in my 2001 toyota camry CE and I am getting a check engine light. I replaced the A/F sensor and the O2 sensor. Still, after 20 seconds of running, the ck engine light comes back on. Also, I switched out the computer. What else is there to check. I am getting a P1135 code. The engine is a California engine.
Thanx.
Old 03-11-15, 07:33 AM
the_tow_guy's Avatar
Not sure if it will matter, but did the computer also come from a CA car? Possible wiring issue since you've changed sensors.
Some info on that code here, although you seen to already have covered the possible issues:
P1135 2001 Toyota Camry Air/Fuel Ratio Sensor Heater Circuit Malfunction Bank 1 Sensor 1 OBDII Engine Light Trouble Code | Engine-Codes.com
Trackbacks are On
Pingbacks are On
Refbacks are On
