help masters mitsubishi lancer 1992 1.5
Old 03-14-15, 01:02 AM
D
Right side break light and pilot bulbs not working.. first i replace the pilot bulb and try it and it works and for the second time its not working same with the right break light it works only when you pressed the break. I tried to switch the working bulbs from the left side still same results. Help please
Old 03-14-15, 04:21 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums! Your profile is not complete so we don't know where you are located. From your terminology, it seems you may be UK. We don't use the terms "pilot bulb" in the US. And it's "brakes". Have you checked the grounding wire to the chassis on the offending bulb? Remember, too, "right" side may mean driver's side to some countries so we need clarification.
