1994 pathfinder egr issue
Old 03-27-15, 12:42 PM
Failed smog. High nox egr tested good cat is good have source vacuum to egr electric switch but no signal to switch to make it work. 1994 nissan pathfinder se v6 3.0 liter.
Old 03-29-15, 06:33 AM
the_tow_guy's Avatar
A little reading on the subject, the first one is a little lng, but has good info:
http://www.aces.edu/~parmega/efi/egr.txt
EGR System Testing
EGR Diagnostics | Car OBD Diagnostics, ECU Chip Tuning & Auto Repair Support
Could be something as simple as a bad ground in the system, but may need extensive work with a multimeter.
