Broken bolts n the manifold
Two Bolts that hold a bracket for the power steering chamber are broke off in the manifold. How do I get them out without getting rippped off at the garage?
87 Chevy Blazer
87 Chevy Blazer
Before you start drilling and using an ez-out, is any of the bolt still sticking out or at least flush? Try a small hammer and chisel and turning it out.
But before you do anything, make sure you soak them with penetrent. If you have access to some torches, (not a propane torch, not hot enough) try heating them up and using some beeswax. The head broke off because of corrosion and heat locking the threads.
Good luck with this, not a fun job!
Broken bolts
If there is any part of bolt still sticking out and you have access to a welding equipment, you can weld a flat washer to the end of the bolt and then weld a lug nut onto the flat washer. Then use an acetelyne torch to heat the metal and the bolt will come right out.
