2000 infiniti I30 how to remove glue
Old 04-30-15, 02:03 PM
K
How to remove glue from the ignition key hole my key only goes half way in ? Is there a spray i can use anything?
Old 04-30-15, 02:05 PM
Received 408 Votes on 364 Posts
Welcome to the forums Karena!
What type of glue and how did it get there?
Old 04-30-15, 03:58 PM
K
boyfriend white gorilla glue its like foam
And Thank you
Old 04-30-15, 04:25 PM
Received 1,525 Votes on 1,408 Posts
In the presence of moisture.... Gorilla glue foams and then hardens.
I guess this was some kind of sick joke because I don't think there is a way of getting it out of there if it's hardened. How long has it been in there ?
You are probably looking at a new tumbler.
Old 04-30-15, 05:24 PM
K
a new tumbler how much could that run ? my key only goes in half way wd40 wont work huh? thats crazy
Old 04-30-15, 09:12 PM
There is nothing I know of that dissolves cured Gorilla glue. Once that dried in the tumbler it was permanent.
I believe that ignition switch/tumbler is held in with safety bolts that need to be cut. I could see a $250-300 job.
Old 05-01-15, 03:51 AM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
"Ex" boyfriend I would hope. Also factor into cost that replacement key/computer may need to be programmed and the tow to a garage..
