2004 Toyota Camry A/C
Old 06-04-15, 04:47 PM
H
The light in the middle of the A/C button on my grandson's 2004 Toyota Camry does not come on and no cool air from the vents. Is there a fuse or relay that would cause this problem? If so, where is it?
Old 06-05-15, 06:52 PM
ukrbyk's Avatar
Received 16 Votes on 13 Posts
Low freon trips pressure switch and then it shuts down the system. You should have a little peep glass on one of the lines showing freon flow.
Likely simply needs to be recharged.
Old 06-07-15, 04:58 AM
H
Problem fixed
Went to grandson's house. Looked in Users Manual. Found location of 10 amp A/C fuse under hood. Checked location and no fuse.
Put in new fuse. Light in center of A/C switch comes on when switch pushed and A/C works.
Told grandson fix. He said a month ago his horn stopped working. He took it to a mechanic. Mechanic said horn fuse was blown and blows each time horn fuse was replaced. Mechanic kept car overnight and fixed horn short. Mechanic apparently used spare fuse and A/C fuse during diagnostics of horn short and then forgot to replace A/C fuse. Without a fuse, A/C did not work on first hot day after horn short fix.
Old 06-07-15, 02:20 PM
ukrbyk's Avatar
Go figure. Glad you fixed it.
