Repairing gxp bonneville 2004 need help
Old 06-14-15, 02:18 PM
I have a 2004 gxp bonneville with the northstar engine. I am trying to remove the front valve covet to replace gasket and I need to know if I have to remove the pulley for the water pump to get it off
Old 06-14-15, 06:48 PM
chandler's Avatar
Certainly you are using a breakdown book to help you along. I would check at the auto parts store and obtain one if you haven't already done so. They will tell you how to do almost anything, because they are based on actual tear downs and rebuilds.
Old 06-15-15, 10:09 AM
Gxp
Had to pull the pulley to remove the valve cover now to replace the gasket I used a power steering puller word great off to get the gasket
