Automatic side door does not open
Old 06-30-15, 05:38 PM
2001 Pontiac Montana The passenger side automatic sliding door does not work. Won't even open manually. I press the button I can hear the lock motor work to unlock the door but it does not open nor will it budge manually. It used to work on and off before but I think the drive motor has finally failed.
Old 06-30-15, 05:47 PM
That will certainly keep the door from opening.
Old 07-01-15, 05:46 PM
So the motor will prevent it from being opened manually also?
Old 07-01-15, 08:56 PM
That strictly a motor operated door.... correct ?
In other words.... it never worked where you could manually slide the door.
