Transmission in second gear will not shift into third gear!
Old 07-01-15, 05:34 PM
2000 SL 2 saturn will go in reverse and second gear will not shift into or third or drive! Will not shift manually.
Old 07-01-15, 05:56 PM
Temporarily Suspended
Take it to AutoZone. They will check it for codes. Also, shift the car by hand. Start in low & shift it manually. See if it shifts then.
Old 07-02-15, 03:41 AM
Is this an automatic or manual transmission? .. btw - welcome to the forums!
Old 07-02-15, 04:17 AM
lawrosa's Avatar
Super Moderator
Sounds like shift solenoid. Yes if it threw a code get the code read to make sure.....
Old 07-02-15, 01:06 PM
the_tow_guy's Avatar
Second gear could also be the "limp" mode, so codes may point to the problem.
Old 07-02-15, 01:54 PM
Good point tow guy. I bet that's it. It's in limp mode.
Trackbacks are On
Pingbacks are On
Refbacks are On
