replace 86 Cavalier starter
Old 04-02-01, 11:16 AM
Guest
I need to know how to replace starter for a 1986 cavalier 4 door, 4 cyc.
Old 04-02-01, 09:33 PM
knuckles
Arrow
It's a piece of cake!
Disconnect negative battery cable.
Remove torque convertor inspection cover.
Remove starter mounting bolts.
Lower starter & remove electrical connections.
Installation is reverse of removal.
Pick up a Haynes manual at your local auto parts store if you're still not clear on the procedure.
Old 06-17-03, 10:50 PM
Can anyone tell me if it is the exact same procedure with a 92 Cavalier? (4 cyl.)
Thanks.
Old 06-18-03, 03:56 AM
Joe_F
See autolibrary.org in my signature file below.
Old 06-19-03, 12:12 PM
jonathan_71730
Cool starters
dis-connect battery cable's and follow the positive wire to your starter should have to bolts take them out maybe a something they call a crossmember in your way but i don't think so on that model.it's simple just follow the positive battery cable and take it off.not everyone in here understands ase talk. "hope i helped you".
