How do you re torque over tightened wheel nuts?
Old 07-13-15, 09:05 PM
When the wheel nuts are too tight, what exactly are you suppose do to re torque them safely?
Do you simple loosen each nut just a bit, or until somewhat loose & straight after re torque it? One nut at a time?
Or loosen all first while jacked up & re torque in the star pattern?
thanks
Old 07-13-15, 09:20 PM
XSleeper's Avatar
Loosen all slightly (no more than 1/4 turn at a time), moving in the correct sequence for the number of lugs on your rims.
https://tireguides.com/TireTips/TireDocument/2
Then retighten to specifications, 1/4 turn at a time, using the same sequence for tightening.
Old 07-14-15, 03:44 AM
Thanks, appreciate it. sounds very simple.
