2001 saturn
Old 08-05-15, 02:56 PM
2001 saturn
Hello, daughter has a 2001 Saturn 4 door sedan, recently started losing antifreeze and over heating. I looked all over and cant see a leak any where, she needs car to drive to grad school this month. Any advice? Thanks
Old 08-05-15, 03:54 PM
XSleeper's Avatar
If there is no leak it must be a head gasket, and its getting sucked into the engine and burned. Notice any extra smoke out the exhaust?
Old 08-05-15, 04:08 PM
Thanks XSleeper have not noticed, but I will look closer, will it be white smoke?
Old 08-05-15, 04:12 PM
XSleeper's Avatar
Usually, yes...................................
Old 08-06-15, 03:14 AM
The coolant can only go 3 places; outside due to a leak or overflow, out the exhaust or into the oil with the latter two usually being a head gasket. How much coolant is it using?
Old 08-06-15, 03:32 AM
If it is overheating , look for other issues , too . Make sure the thermostat is opening up properly . If it has electric radiator fans , make sure they are coming on .
Does it over heat if the A/C is not on ? Any radiator air flow restrictions ? Is the suction hose on the water pump , to the radiator soft and collapsing with higher engine RPM's ?
Any chance there is a small leak than only happens when driving down the road . After the system is warmed up & pressured up ?
As some one else has indicated , check for coolant in the engine oil .
Check / replace the radiator cap . Check the coolant reservoir tank for a leak . Check / replace the hose between the reservoir & the radiator .
God bless
Wyr
Old 08-06-15, 12:58 PM
thanks WyrTwister will check these things and post back, she drove car this morning 17 mi to work and temp gage didn't do even go half way. I filled up coolant before she drove
Old 08-07-15, 03:50 AM
Check the coolant level when she gets home .
AFTER it cools off !
Can you smell antifreeze ? That is another sign of a leak , somewhere .
God bless
Wyr
Old 08-07-15, 03:56 AM
If you smell anti-freeze in the cabin that often indicates a heater core leak. If so, check for dampness on the passenger side under the glove box.
