1993 ford ranger 5sp manual
Clutch pedal goes to floor hydraulic leak where line goes into a rubber seal just as line enters transmission.Can this be repaired without pulling tranny??
Doubt it. Sounds like the slave is inside the bell housing on yours.
| Repair Guides | Clutch | Slave Cylinder | AutoZone.com
According to this, the master and slave have to be replaced as a unit on an 83. Maybe someone has more experience.
there is an o-ring that can be replaced once you separate the lines. there is a special tool for that though.
