2011 Toyota Sienna driver seat movement
Old 09-21-15, 07:34 PM
Hi,
Driver Seat movement switch works for moving up and down but when I try to move forward and backward seat doesn't move. Any suggestion on what to look and where to start to diagnosis of the problem.
Please help.
Thanks,
Old 09-21-15, 10:47 PM
There are two motors controlling that...... one for position and one to raise the seat.
If you operate the up/down switch...... observe which motor is operating the linkage.
The other motor will be the position one. I would un-plug it and check for 12v with a meter or test light while operating the switch. If you find power that would indicate a defective motor or jammed mechanism. If you don't measure voltage then it's the switch.
For the most part... the switch is usually the problem.
Old 09-22-15, 04:58 AM
Thanks very much Pete. I will check this and hopefully will be able to find the issue
Old 09-22-15, 05:27 AM
the_tow_guy's Avatar
Does that model have a seat-mounted side-impact airbag?
Old 09-22-15, 01:00 PM
Hello the_tow_guy
Do you mean airbag on door?
SS
Old 09-22-15, 01:56 PM
I believe he's asking you that so if you go probing around or unplugging connections under the seat you don't risk an airbag deployment.
Old 09-23-15, 05:58 AM
Bingo.
And some vehicles have them mounted IN the seats:
http://www.safercar.gov/Vehicle+Shop...mpact+Air+Bags
Old 09-23-15, 01:03 PM
Ok. I just checked and I don't have the side-impact airbag.
Its little space issue at the bottom of driver side seat. Took out the bottom cover but could not take out the cover which has switch. I will put a pic today evening to see if anyone has any suggestion.
I can do it but only if I have good instructions so would be great to have some suggestions.
Old 09-24-15, 12:21 PM
Ok Finally after research it looks like this seat might have four motors and don't know where to start.
1. Seat Sliding Front and Back
2. Height adjustment
3. Back rest seat adjustment
4. Lower back adjustment
see pics below and pls. suggest where to start..
Name:  Front Seat Side View.jpg
Name:  Front Seat Under.jpg
Old 09-28-15, 09:24 AM
NJT's Avatar
NJT
NJT is offline
BEWARE!
YELLOW connectors are USUALLY part of the "SRS" (Supplemental Restraint System)!
Could be a seat occupancy sensor or the like...
Please know what you're doing before you blow up an airbag!
Old 09-28-15, 01:33 PM
Thanks NJT. You are right I will make sure to take each step carefully.. I did contact toyota customer service. They called and are checking if it can be covered.
