2010 Honda Accord brake lights/turn signal/headlights interfering with eachother
Old 09-23-15, 07:44 AM
Exclamation 2010 Honda Accord brake lights/turn signal/headlights interfering with eachother
PROBLEM:
My brake light and turn signal indicators started coming on, showing they were going out. I went and got new brake lights and installed them. After that point, when I use my turn signal while braking, or brake while my turn signal is on, both do not work. Additionally, when my headlights are on my brake lights will not work.
WHAT IVE TRIED:
I have tried to locate the turn signal/brake light fuses with no success....I have changed the brake bulbs, which then caused my brake lights to work, but not when using my turn signal or headlights....is there a fuse for the brake lights and turn signals?!
Old 09-23-15, 01:17 PM
Welcome to the forums.
You should have three bulbs in each rear light assembly.
Top bulb....... dual filament bulb for brake and parking light. (#7443)
Bottom bulb.... single filament for back-up lights (#7440)
Side facing bulb..... single filament amber colored (#7440A)
In the underhood fuse box....
#12 (15A) should be brake lights and horn. See if horn works.
#10 is the hazard lights (4ways) see if they work.
In the underdash fuse box...
#15 (7.5A) is the parking light lamps.
I haven't found the directional fuse yet. You could check your owners manual where you'll find all the fuses listed and their location.
The directional lamps should not have anything to do with the brakelights.
Old 09-23-15, 04:31 PM
NJT's Avatar
NJT
NJT is offline
No, not normally, but...
I would be looking at defective grounding ... 9 out of 10 when one system interferes with another, it's a grounding issue.
Once had a car that the radio went on and off with the turn signals... bad ground.
